Nordic Track X11i Commercial Incline Trainer Treadmill Logo
A
Anonymous Posted on Mar 21, 2013
Nordtrack x11i console - Nordic Track X11i Commercial Incline Trainer Treadmill
1helpful
How do you remove the lower center console on a 2000 Olds Intrique
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
1helpful
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
How should I lube my NORDICTRACK X11I
Check the video all the treadmill follows the same procedure of lubricating it.
5helpful
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
3answers
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
