I have some files in mp3 music folder that are visible only in there and recently added folder. If i try to use them i get message " no file". Also they do not appear on file browser or when i connect mp3 with pc. Any ideas how i could get rid of them? p2. I tried formatting, but on mp3, it didnt do anything, only showed now formatting message until battery finally. And trying to do in though pc, i got message cant format
SOURCE: DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
SOURCE: my philips gogear 2gb mp3 player will no accept any format
maybe try uninstall program on pc then put instalation disk back in and reinstall
SOURCE: file check error in
Hi. this is rajesh gp from sivagangai. it is very easy to solve. just long press your iriver menu(M) and goto settings -> advanced -> format. then copy any music files from your pc then enjoy with your songs. [[email protected]]
SOURCE: i formatted my Philips SA1922 2GB MP3 Player and
when you format any drive you erase everything that is on them. you need to find the original files from the manufacturer to rebuild your system. philips should have files to download on their website philips.com. make sure your item is registered and they should give them to you for free. next time be sure to only delete your files. and only format first time use storage devices. the player should have already been formatted for your use.!!!!
SOURCE: Zen Stone Plus show 'File System Error" after format
u can download the recovery tool from creative.com...quick and easy...good luck...XD
