Door lock wouldn't activate for self cleaning.
SOURCE: Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
[email protected]
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
SOURCE: GE oven door won't unlock
Not usually, there may be a problem in the locking mechanism. You must check it out and get that fixed.
SOURCE: Amana range ARG7800E Oven, Broiler and Self Clean will not ignite
Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
tti
