You buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Hi Rod, actually, I was looking into possibly replacing the whole head assembly with the Aero-flex assembly (really, to make replacement easier for my wife as I travel a lot) as opposed to replacing just the string.
A little more research and I figured out that I need to crimp and remove the retaining washer in the head assembly to do so.
Thanks for the reply, though!
A video of the process for anybody else looking for this is here:
http://www.aero-flex.com/installation_instructions_v6.html
