follow this steps and fix it. God bless you
No power
- Check
if the power cord has been properly connected to the power outlet.
- Check
if the main power has been switched on.
(DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or
Power button does not work
- Try
turning the power off and wait 3 seconds before turning it on again.
- Make
sure the TV and VCR (if connected) are set to the correct channel or
line.
Does not play disc
- No
disc. - Load a disc into the tray.
- Disc
has been loaded upside down. Place the disc with the label side up.
- Disc
region code does not match region code of the player.
- Disc
type is not the correct type to play.
- Disc
is damaged or dirty. Clean the disc or try another.
- Moisture
may be condensed inside the unit. Remove the disc and the leave the
power on for one or two hours.
No sound
- Check
if the TV and Amplifier (if connected) is turned on and set correctly.
- Check
if the TV, DVD player and Amplifier are connected properly.
- Make
sure the TV, DVD player and Amplifier volume are not set to Mute.
- There
will be no sound output during Reverse Play / Pause / Step
/ Slow / Search.
- If
the DTS soundtrack is enabled in the DVD Disc Menu, but you are using
Stereo Analog audio, the sound will not work. Try switching the
soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
Turn
on your DVD player.
Open
the DVD player's main drive, also commonly called the DVD "tray." The
region cannot be changed while a DVD is in the machine, so many DVD players
require the tray to be open as an extra precaution.
Push
"Info" or "Setup" on your remote.
Use
the remote to select the "Region" option as indicated on your TV
screen.
Select "Region 9" to change the system to
multiregion formatting. Regions 1 through 8 represent specific geographic
locations and will not allow multiregion playback.
