Question about Water Heaters
How to remove broken off hot water tank drain nipple
Drain nipple broke off
    New Friend:
    Problem Solver:
  • 15 Answers
You can purchase an ease out tool from Home Depot or Lowe's, It fits inside the broken pipe and when you rotate it counter clockwise it tightens inside the pipe and removes the nipple. (Be sure to check the inside pipe diameter first)
Posted on Mar 21, 2013
SOURCE:
Kenmore power miser 5, water only stays hot for
sounds like the down tube broke off On the cold side there is a tube that takes the cold water to the bottom of the tank and heat up to replace it . That causes it to help push up the hot water . You will need to remove the nipple bringing in the cold water and replace the tube. you can check on the tube after you remove the nipple by sticking in a finger and pulling up the remains of the tube if it was not attached to the nipple if there is nothing there same thing you need a down tube.
Oct 09, 2014 | Water Heaters
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
Water is leaking from the pipe on the top of the tank (Reliance 606 electric) where the hot water comes out and goes into the house. Likely causes?
If tank is rusted out, then that is caused by depleted anode rod, or tank that is not electrically grounded on hot side pipe.
If pipe nipple is rusted out, then that can be caused by improper connection between copper and galvanized pipes, and caused by non-grounded hot water pipes.
If tank is leaking, replace it.
If nipple is leaking, remove with pipe wrench, apply teflon tape or joint compound on threads, and install new nipple. Replace anode rod if possible. Correct copper-galvanized connections. Add ground wire between hot and cold pipes.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Aug 25, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water tap creates an annoying noise in the mh. The noise is coming from the Atwood hot water heater. (2007 Coachmen Mirada).
Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
Jun 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water is coming out of the nipple around theb hot water oulet
If it is an old water heater it may be a leak at the weld . If it is a newer water heater it may
just need tightening, OR shut off water to the heater itself and shut off power, open a hot
faucet or tub and connect a hose to the drain of the water heater. Drain about a bucket
worth of water from the heater before removing the threaded nipple to apply some
pipe thread seal or teflon tape. I recommend using rectorseal on the nipple and port. From
what you describe it is the nipple itself and not the popoff. If it is the popoff then the
procedure is the same for it's removal (they are replaced only and not serviced)
If the nipple has copper line to it you may need to cut it with a tubing cutter and use
a compression coupler (usually 3/4 inside diameter but sometimes 5/8 inside diameter)
The inside diameter of the coupler will be the same as the outside diameter of the pipe.
These are readily available at any home improvement retailer.
make sure to refill tank until water flows at tap before restoring power.
Feb 26, 2011 | Water Heaters
I have a rheem heater M/N 81V40D how do I change the anode?
Unless you see a large hex head socket to remove on the top of the water heater, many
anode rods are built onto the hot side nipple. They are almost the length of the water heater.
Hopefully you have room to remove it if this is the case. If you see a hex nut that is silver
gray on top, then shut off cold water to the heater. Release some hot water at a tap to relieve
pressure on the tank or drain some out at the bottom which is better. Make sure power is
off to unit first or gas is off . Unscrew nut or nipple counterclockwise to remove. Best to
remove with a socket wrench or box wrench if it's a nut and a good pipe wrench if it's
on the nipple. Several light taps with a hammer if necessary on the handle of the
wrench or pipe wrench should help. Hopefully the nipple has a removable flex line if
it's located there. (Remember it's on the hot side and should be marked on the top
of the heater).
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Slight water leak from plastic drain fitting on rheem fury 40 gal gas water heater
You can try to crack it open and get a little piece of crud out of there, I'm sure that is all it is, Just get a tray or something to catch the water, It should stop it, If it gets worse, turn the water off to the heater, then open the valve and hope the bigger piece of crud comes out. It is about all you can do, other than drain the whole thing and take the valve apart and replace the rubber in it. Check it out, Hope this helps.
Dec 12, 2010 | Rheem Water Heaters
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
MY GE PRESSURE RELIEF VALVE HAS JUST STARTED LEAKING. WHAT SHOULD I DO ? GE SMART WATER HEATER GELN0705CO3984
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
Jun 14, 2010 | Water Heaters
Not enough hot water to complete shower. Noticed
If it is a new water heater it might be that the water supplies are crossed. The cold water should be installed on the right hand side of the tank or on the bottom if your tank hooks up on the side. If its an older water heater the dip tube may have broken off. This is a tube that runs from the top of your water heater on the cold side to the lower portion of the tank.It puts the cold water in the bottom of the heater which pushes the hot water to the top.To change the dip tube out you must disconnect the cold water supply from the 3/4 inch nipple at the top of the tank. Then with a pipe wrench unscrew the nipple from the tank it will have the remainder of the tube on it.You can get a replacement dip tube at a plumming supply. Installation is opposite of removal. If this is your problem I suggest you get a new water heater .Usually its caused from minnerals in the water or buy two dissimiler metals being connected together in the water piping system causing corrosion Your water heater will probably fail in the near future.
Dec 15, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
