Computers & Internet Logo
Posted on Mar 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change ip address - Lenovo Computers & Internet
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Mar 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
7042
Points
46
Is your ip Static or Dynamic. If your ip is static then you cannot change your ip address. Otherwise your ip address is dynamic, you can change your ip address by resetting your modem. After your ip was changed you can check your network ip address at Ip-details.com .Here it will display Internet service provider,IP address, location, Longitude,latitude and so on.
joecoolvette
Level 3:
  • Lenovo Master 5,660 Answers
  • Posted on Mar 21, 2013
joecoolvette
Lenovo Master
Level 3:
Answers
5660
Questions
0
Helped
2194456
Points
18014
I believe the information contained in this link, is better than the prattle I could post,
http://whatismyipaddress.com/change-ip
Regards,
joecoolvette
2answers
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
1helpful
2answers
What is the ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.
There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address.
Hpow u change ip adres
Method 1:
Step 1
Step 2
Step 3
Step 4
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
How to change ip .. someone tell me
You cannot change the ip address by yourself.It is provided by your ISP.If you using static ip address it will not change even if you reset the modem or switch off and on...If your ip address is an Dynamic ip address you can change it easily by resetting the modem or switch off and switch on it...To check the ip address before and after changing you can visit the site Ip-details.com and check the ip and its details. you can also use Proxy server or Hide ip address software to change the ip address .
What is ip address and how can i change it
An IP address (Internet Protocol Address) is a logical address of a network adapter. The IP address is unique and identifies computers on a network. An IP address can be private, for use on a LAN, or
public, for use on the Internet or other WAN.
You cannot change the ip address, if you using static ip address.If it is dynamic ip address, you can change it easily by resetting the modem or switching it off and on.you can also use Proxy server or Hide ip address software to change the ip address.
To check the ip address before and after changing, you can visit the site Ip-details.com. Here you can search IP,domain host and it also includes city, country, global latitude & longitude coordinates etc.
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
1helpful
3answers
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
2helpful
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
3answers
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
