I also need to warm it up in the morning 3-4 minutes before driving or it sticks and hard shifts really bad 1st to 2nd gears too. Otherwise it drives fine, especially well on the highway.
SOURCE: transmission won't shift to 2nd and 3rd gears goes from 1st to 4th.
Doesn't sound like a simple fix. I would suggest having it serviced.
SOURCE: 1994 325 BMW shifting from 1st - 2nd gear is hard
unfortunately yes it does.its sounds like your 2nd gear synchro is out.unfortunately your tranny needs to come out to fix it.does it only between 1-2? or other gears? if all gears your cutch is goin but just between 2 specific gears a synchro times the gear teeth so they lock in and its off and teeth on the gears are the grinding you are hearing.sorry to have to tell yah that one.i always loved my old 325 is model always fun to drive.
Testimonial: "quick and informed thanks"
SOURCE: BMW 523 Auto gerbox when cold change from 1 to 2 gear is hard
hello there
The problem is with the gear oil. To keep ahead of the rest BMW started what they call life time oil for their gear boxes, though that sounds great it doesn't really work in reality, they have now gone back to recommending a gear oil change every 60k miles.
In short you need to change your gear oil and soon, the oil in your gear box is no longer effective and will damage the gear box. You'll need about 5 litres for your car and costs around £15 a litre, expensive stuff!! I had the same problem with my 328i auto, the dealer was clueless and kept quoting the lifetime oil, I changed the oil and the problem has gone and it's so much smoother.
Hope this helps, please don't forget to rate me.
SOURCE: My ABS light came on and 20 miles later after
You will need to get it diagnosed to see which wheel sensor is bad.
If both the abs and the brake light are on on the speedo dont work them the module is bad.
Also make sure the tire pressures are the same
SOURCE: TRANSMISSION 2nd to 3rd GEAR HARDSHIFT
