SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to
create statistical graphs, it is configured to accommodate the specificities of the
problem. However that configuration remains set after you terminate the
problem. So when you try to use the calculator to do other problems it
uses the stored configuration parameters, which may be incompatible
with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To
make a long story short, you should make it a habit to reset the Ram
every time you want to do a new problem. If for reasons of you own you
do not want to reset the Ram, you can prevent this type of errors from
occurring. This is how you do it.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
SOURCE: err:syntax when I try to graph with ''-''
The calculator has two minus signs
These are the technicalities, in which you may not be interested. On calculators, the two operations are implemented differently, with two signs, the regular minus sign -- , and the change sign (-) usually smaller in size than the regular -- sign and raised above the main line.
Examples. Let (-) be the negation and -- the regular minus.
Suppose you have to calculate X^(-2)*X^(-1/3)
You can enter it exactly as it is written above. In this case, you must use the change sign (-) in both factors.
You can also decide to use the power rules and enter the expression as X^( -2 --1/3). In this case the first minus is the negation and the second is the regular minus.
I could go on with a few more examples, but that will take us away from your present concern.
In short.
I hope it did not bore you death with details you do not care to know about. I do hope that it will help you prevent this type of syntax errors.
Do not forget to rate the solution
SOURCE: How to plot a graph on TI-83 plus texas calculator?
Prepare calculator to graph
Turn StatPlotsOff to avoid errors:
Press
[2nd][STATPLOT][4:PlotsOff][ENTER].
Setup Graph type
Entering the functions to draw.
Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
Drawing the Graphs
ZOOMING
You can also press [ZOOM] to adjust.
The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
In the window screen you can set Xmin=-180, Xmax=180, Xscl=10, Ymin= -0.6, Ymax= 1.5, Yscl=1. The minus here is the change sign (-) to the right of the [.] dot.
Testimonial: "Thank you so much for your kindness in helping me. "
SOURCE: whenever i try the graph
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
