Polar S150 Heart Rate Monitor Logo
A
Anonymous Posted on Mar 21, 2013
Istruzioni per l'uso del polar electro patented ce0537
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Feb 07, 2009
SOURCE: where can i get a MANUAL for polar heart monitor model ce0537
Check the links below:
User Manual
Video instructions
TABLE OF CONTENTS
loz0
Gould's Jewellers
  • 25 Answers
  • Posted on Aug 22, 2009
SOURCE: Polar CE0537
I have changed batterys in these watches but i can only describe the process from memory which may be faulty. You may or may not have to remove the strap depending on whether it covers any of the case back. Unscrew all screws on back and remove. I believe these watches have a triangular spring loaded plate over the battery which needs to be slid out to (bit tricky) note which way up battery is. Replace battery 2032 i think replace cover short AC or AR with +ve replace seal,back,screws etc. this is a link to manual for confirmation http://www.devicemanuals.com/guide/Watch%20and%20Clock/Polar/Polar-F4-User's-Manual-==TVRFM09URXg=.html
Anonymous
  • 347 Answers
  • Posted on Jan 06, 2011
SOURCE: Polar electro oy CE0537-T41 N2965 chest strap Does
No. all the solid rubber straps are sealed in batteries. Only the T-31 wealink has a replaceable battery. The T-31 will work with your S-150 watch. If you need a replacement because yours has stopped working then that is an option. It's about $10- more.
Anonymous
  • 347 Answers
  • Posted on Apr 25, 2011
SOURCE: My wife asked me to
There is a link to download any Polar manual in PDF form in my tips and tricks page.
Are you sure there is no button in front? Polar watches are all activated for exercise recording by a front button. And if it is an A5 as the request and picture show there is definitely a front button.
On the back of the unit, near the upper portion of the backing will be the model number it will be a letter/ number code like A5, M32, etc... The CE0537 is a different coding than the model itself. You will need the model number for the correct manual.
Anonymous
  • 75 Answers
  • Posted on Jun 20, 2011
SOURCE: i need the manual of my polar electro ce0537
Hi! Welcome to FixYa,
Please refer to the link below for the manual of polar electro ce0537:
http://www.polar.fi/en/support/product_support?document=/gip/PKBStoGIP.nsf/LINK/xAF42D5B7E6C545CF422569F400405E36?OpenDocument
You have a great day and thanks for using FixYA!
Changing battery
Per the owners manual you should not change the batteries yourself because it is a waterproof system. http://fitness.manualsonline.com/manuals/mfg/polar/f2.html?p=13
http://www.polar.com/us-en/support/service
1helpful
I need the manual of my polar electro ce0537
1helpful
Cerco le istruzioni per l'uso del T 1030 D: potete aiutarmi? e-mail: [email protected] Sergio Proietti
Hola Sergio.
Estoy
usando Google Translate.
http://translate.google.com/#auto'es'
Manuales de Gardena son el link.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Utilice Google traducir. Copiar el p?rrafo del manual. Pegar en el apartado traductor Google.
1helpful
SMARRITO ISTRUZIONI PER L'USO, COME SI MEMORIZZANO I CANALI E SINTONIA FINE. GRAZIE
Halo
Apa nama jenama dan nombor model TV anda. Tanpa itu bagaimana saya bisa posting penyelesaian sebelum anda. Sila kirimi saya nama jenama yang tepat dan nombor model TV anda dengan FixYa. OK.
3helpful
My wife asked me to set the time on her watch. She no longer has a manual. Can you help? It is a polar CE0537 Polar Electro and has two side buttons but no button in front. Thank you.
15helpful
Setting Polar CE0537
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Top Polar Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
