SOURCE: I have a coby Kyros
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Have you tried taking the battery out? That solves a lot of problems.
SOURCE: I forgot my unlock code for my Coby Kyros... how
i NEED Help .. I Have A Coby Kyros MID8120 And I Got Locked Out .. I Have Been Looking Around For Help But Nothing .. If Anyone Knows .. PLEEEEAAASEEEEEEEEEEEE HELP ME .
:c
SOURCE: coby kyros mid 7022 is stuck on lock scteen, how
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
SOURCE: i want to up root
Rooting your phone and installing your own custom ROMs available online gives a new lease of life even to the first generation of Android Phones.
Here is a step by step rooting guide.
