the turn signal circuits are shorted,,the fuse blowing saved you from a fire.(burning harnesses)
faili on left or right or both and HAZARDS? SORRY 3 fuses to learn that.
USA answers, Chevy S10 only
there are 2turn fuses, I see, in the schematics.
LT-turn and RT-turn, so now you know which side is shorted. just a glance and bingo , side. bad know, cutting work in ;1/2.
but, there is 10amp turn fuse too, that runs the turn flasher module
so 4fuses, turn left and turn, main and haz main.
this is bad.
any thing in this whole turn system can blow fuse turn main, BLK.
but learning if only one side fails ,is great moment,
if both fails, the problem is this module or the turn swtich is shorted.
I have a Rockford fosgate Prime R500-1 ihave hooked up to a set of MTX terminater 12's 2 ohm . I used a scoshe 680 watt wireing kit with 8 awg power & ground wire. I ran all my wireing and doubled checked it as soon as I put my main 60 amp fuse in the amps both 30 amp fuses blow ???????????????
What was the solution to this problem?
