Hi Diane,
Just downloaded the manual for your vcr it says:
1 Press menu
2 press up/down arrows to Function Set then press ok
3 press channel up/down arrows to Auto picture then press Ok or shuttle plus right arrow to set to on or off when using rental tapes set either to on or off to give the best picture
4 to return to normal press menu
For recording
1 load a cassette make sure the tab on the cassette is intact if not put some cellotape over the hole
2 set channel press up/down arrows then press enter
3 select tape speed sp/ep
4 press and hold rec and press play on remote or just press record on unit
5 to pause recording (cut out ads) press pause on remote to continue again press play
6 to stop recording just press the stop button
hope this helps and reflects in my feedback lol all the best
Jim Scott
thanks for answering, I put in a tape and it doesnt do anything, wont play or ff or rewind, when I use a tape from the store it starts playing right away and the features all work, ff rewind stop pause all of it,
Hi
I want to thank you for teaching me also how download the manual. What I read was that I need to use a s-vhs TAPE where as I have been using a hs-vhs, I will go buy a different cassette tape and I think that will fix the problem. I would not have know that if I didn't download the manual like you did' so I think it will be OK when I put in the proper tape
thank you so much
Diane
your welcome but I bought a new tape and it didnt help. Do you know the excact type of tape Im supposed to use, I read on the manual it wont take some tapes for recording, Never heard of that,I thought all vhs tapes were the same. If you have time to read the downloaded manual it will say to use a certain tape and I cant find the box of the one I just bought today
Hi
Thank you again, I will go buy one tomorrow, You are the best and I am a du,mmy
Diane
what is it doing ?? you put a tape in then push record ??? then what ??
