Electric Circuit Breaker Kit for Furnace Logo
Posted on Feb 28, 2009
Melted Disconnect On A Nordyne Electric Furnace
My house is heated with an A series Nordyne electric furnace. A couple of years ago it quit and I had a heater guy come out and fix it. It turned out that the 60 amp fuses had failed. The heater guy showed us that the clips holding the fuses were badly corroded which, he said, led to the fuses overheating and failing. We live about 75 yards from the Puget Sound so our environment is damp and salty. The guy recommended that we clean the fuses and clips holding them on a regular basis to prevent this from happening again.
Good advice which I promptly forgot about until the next time the fuses failed. I got new fuses but before installing them I cleaned the clips on the disconnect and the interlock bar which was also crudded over. The fuses failed again and this time the interlock bar and the disconnect itself got a bit melty.
I understand that Nordyne makes a disconnect that relies on breakers instead of fuses. Given our damp environment I’m wondering if this is a better option than the original system of fuses.
The other thing I need to know is if I should look further for the cause of the fuse failures. The reason I was given; damp, salty air, sounds reasonable to me but should I be checking for other problems in the heater, the heater coils perhaps?
Thanks!
  • 9Frank22 Mar 01, 2009
    Thanks Joe! Currently I'm not using the heater, well, it's busted so I can't anyway. But when I do fix it I will be using the breaker box kit rather than screwing around with fuses. The only other question I have is: Is corrosion from the damp, salty air the most likely reason why the fuses failed in the first place or should I be looking elsewhere for the problem.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1751
Points
10
The corroded surface is causing arcing wich is inturn heating up the whole works,REPLACE WITH PROPER BREAKER AND BOX AS THIS IS A FIRE HAZARD!
Coleman 3500 812 Furnace. I need wiring diagram please?
Question edited for clarity and correct order 'make model (what it is)'.
Question moved from Cars and Trucks category.
Service manual and wiring
3500 Coleman Wire Diagram / Parts manual/ Helpful user ...
HVACpartstore https://colemanhvacparts.com > products > coleman-3...
3500 Coleman Wire Diagram / Parts manual/ Helpful user guide (Download) 3400-811, 3400-812, 3400-816, 3400-818, 3400-820, 3400-823 3500 Coleman Wire Diagram ...
US$7.49 · ‎In stock
Missing: please? ‎' Must include: please?
Problem with nordyne furnace
possible gas pressure wrong and running too hot
I have a nordyne furnace and the heating elements stay on even after the blower kicks off what causes that
If the heating elements stay on all the time with no call from the thermostat, the sequencer will need to be replaced --a common failure of an electric furnace.
How do I know if a fuse is blown in an electric mobile home furnace? Nordyne
trip main breaker in breaker panel, open up furnace and open small door at bottom to access electrical wiring. most of the time on older furnaces , fuse is in series with low voltage red wire..
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Need to download a schematic for an american standard electric furnace.
The nice thing about electric furnaces is that they are all just about identical. Here is a electric furnace manual that I like because it actually tells you how to troubleshoot different components.
http://www.nordyne.com/Literature/359a.pdf
1helpful
2answers
Nordyne FEH017HA-04 furnace wiring
This should be 110v so you will have black wires, white wires and ground wires. The grounds wires both go to the ground bar, the whites wires both go to the nuetral bar, or can be wire nutted together, the black incoming (feed) wire goes to the buss bar that the breaker plugs into and the black going to the furnace goes into the breaker lug.
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
3helpful
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Top Electrical Supplies Experts
vince
NOEL
NOEL
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
