Question about HP OfficeJet Pro L7580 Color All-in-One Printer
Error message: "Door Open"
Printer: HP Officejet Pro L7580
Problem: Cannot print. The error message "Door Open" appears on screen when all doors are properly closed.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
Error message: If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
Just tape the printer door closed. There doesn't seem to be a latch securing it so scotch tape should do the trick.
Posted on Apr 15, 2009
SOURCE:
My HP L7680 printer gives message "print carriage access door or ink cartridge cover is open" but it isn't any ideas how to get rid of message and get printer to work
To resolve print carriage access door or ink cartridge cover open error just dial toll free number HP Customer Service Phone Number +1-800-281-3707 24*7 available for your service with the help of qualified technicians. HP Customer Support Phone Number 1 8002813707Help
Jan 27, 2017 | HP Officejet Pro L7680 All-In-One Printer
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
My HP officejet pro L7580 has stopped printing black. The cartridge has been replaced ( HP original) . Other colours are fine. Printheads are fine. Error message on display: Alignment failed - Refer to...
On this HP the print head is not part of the cartridge. How do you know the print head is fine? Did you just try to do a test page without an alignment?
I know that HP (they suck) will not help you because you are past warranty - Google your question since I am sure that you are not the only person to have experienced this issue.
I think you have a bad print head.
Sep 18, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
Hi I have a HP Officejet L7850 Printer with a "Rear Door is Open" error. I have checked the rear door and I do see the contacts on the door is damage and can not make a proper connection with the sensor. ...
Please follow the steps given in the below document and check if it resolves.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01626835&cc=uk&lc=en&dlc=en&product=2512008
Wish
Aug 01, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
My HP L7580 is messaging that the back door is open. All functions are unable to perform. The door is shut, to the best of my knowledge
laser printer have many sensor at defferent unit like paper input cartridge fuser paper output and some cover, you may try to check a sensor at back cover somewhere around the cover edge that look like a small switch, it can be actived by the cover, the error occur if the small switch not active, press the sensor then power on see what happened, no error you may adjust the sensor position that can be active by the cover. still error need to check the sensor or repair it.
Dec 27, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
2,084 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
