Purchased an ipad 4 and was hoping to print wireless to the hp 3050
SOURCE: problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Your printer has an cable/wired ethernet connection. To use it wirelessly, you need to purchase a wirless print server from HP.
HP Jetdirect Fast Ethernet
embedded print server
(RJ-45 port) for flexible
networking (standard on
the P2015dn and
P2015x models only)
http://www.hp.com/sbso/productivity/howto/it_networkprintserver/basic.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1. Tap (the back arrow) or (the forward arrow) (depending on the app you're using), then tap Print.
2. Tap Select Printer to select a printer.
3. Set printer options, such as number of copies and double-sided output (if the printer supports it). Some apps also let you set a range of pages to print.
4. Tap Print.
