The player automatically connects to the computer in Media Transfer Protocol mode (MTP mode).
For accessing the microSD card in the player, the USB connection in the player has to be set to MSC mode, see: http://kb.sandisk.com/app/answers/detail/a_id/167
Sorry but there are no specific drivers on the CD for this player. I've had this player since '05 and was trying to get it installed under Windows Vista with only limited success. This player seems to work best with Win XP.
The c150 has two modes of operation MSC and MTP. In MSC mode Windows recognizes the player as a flash drive. You create folders using Windows Explorer just like you do on any hard drive and then copy your music files into the folders. The second mode (MTP) works with a music player such as Rhapsody or Windows Media Player (ver. 10 or higher). SanDisk bundled Rhapsody on their CD and I just installed it (today) on my Vista PC and it seems to work OK. Any files dropped on the player in MTP mode are invisible to the music player running in MSC mode. However, all files added to the player, regardless of the mode used, are visible as one big happy list when you use the player.
You set the mode you want to use before plugging the player into a USB port by going to "menu/settings/USB" on the player then choose either MSC or Auto Detect (defaults to MTP).
SanDisk has very little tech support info about this player on it's web site. I hope this is helpful.
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated.... Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) Then connect to your computer and see if it works Hope it does..........Please rate
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive. • In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced. • The difference with media files, specifically music files, is that they demand much more management. • Downloading services can require special licensing and a limit on the number of playbacks a music file can have. • The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers. • For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP. • Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center. • We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Well, is it in MTP mode or MSC mode (menu > settings > USB)?
If it's in MTP mode, Windows Media Player should recognize it.
If it's in MSC mode, it acts like a USB thumb drive.
You should be able to add music in either mode, but I've found MSC mode simply doesn't work, though it once seemed to. Also, the Sansa m230 will not work with USB 1.1, only 2.0. Next time, I'm getting something Rockbox runs on!
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Hi there , in the settings menu in your player if you go into usb you can change it to msc mode and it will read as a normal usb drive so you can transfer songs etc
Hi.
I hope this info would help:
Your Sansa E260 has 2 modes: MTP (Music Transfer Protocol) and MSC (Mass Storage Class). Your Operating System recognizes each mode differently, and music files saved in one mode would not be seen when you switch to the other mode, and vice versa.
Try switching to each of these modes, then plug it to your computer and browse the player. To switch modes, use the following menu navigation:
Menu >> Settings >> USB Mode
This would give the choice of MTP and MSC.
