SOURCE: square root of 0.5
Hello
If you want a number in decimal form all you have to do is press [S<-->D].
Hope it helps
SOURCE: How do I get an approximate answer instead of a radical?
press the [S<->D] button. it's directly above the DEL key.
SOURCE: can the calculator give the cube root of 16 as 2
If your calculator Input/Output mode is MthIO, Yes. If Mode is LineIO, the result will be a decimal number.
To set MthIO, press [SHIFT][MODE] to access (Setup) then press 1 to enforce [1:MthIO].
SOURCE: i dont know how to
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
SOURCE: simplifying radicals on fx-115ES
If your calculator is SetUp for Math Input/Output (MATHIO), a result that gives a radical will remain in radical form. If a radical appears in a denominator the whole expression is rationalized: Any radical left is put in the numerator. 1/Sqr(3) is displayed as Sqr(3)/3.
