Toro& Electric String Trimmer Logo
A
Anonymous Posted on Mar 20, 2013
How to replace spool on toro 51352
1 Related Answer
Anonymous
  • Posted on Aug 30, 2009
SOURCE: I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
Toro 51352 line breaks immediately
  1. Make sure the line size is correct and compatible with your trimmer. Using a line size that is too small or too large can cause problems with the trimmer.
  2. Check the spool for any debris or foreign objects that may be causing the line to break.
  3. Check the line for any kinks or knots that may be causing it to break.
  4. Make sure the trimmer is properly calibrated and that the line feed mechanism is functioning properly.
Jan 03, 2023 • Toro Garden
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
2answers
Does Toro still make 88035 spool cap replacements? I cannot find them anywhere.
According to this large online parts distributor, that part has been discontinued.
http://www.partstree.com/parts/?pn=88035
I found this one on Ebay....it looks like the spool with the knob for a 10" electric trimmer. I tried!
http://cgi.ebay.com/TORO-PREWOUND-SPOOL-ELECTRIC-TRIMMERS-PART-88180-/280505426528?pt=LH_DefaultDomain_0&hash=item414f6d2260
1helpful
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
2helpful
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
1helpful
2answers
Aug 30, 2009 • Toro Garden
1helpful
Trying to remove part that fits on motor shaft.
Grab the bottom of the motor shaft with a pliers and the plastic part will twist off by turning it counter clock wise.
10helpful
3answers
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
