This typically means the drive has gone bad. Try reformatting the USB drive. Some manufacturers also provide diagnostic/formatting tools on their website that might be able to fix it. But likely it will need replaced. Lucky 2GB USB drives now only run $7.99 or less.
Is the light on the genx 2gb usb illuminating??
If the usb port is NOT a 2.0→ it may NOT run.
* Try opening 'My computer' and searching for the usb drive there.
* advanced effort- try using 'Device manager' to see if your usb port is functioning porperly.
# does it work on another computer?
0--- Return item
the most defalt of option is reinstal the driver and check in the Device Manager the usb you have 3 usb root hub,1 enhanced pci to usb controler,update and try again,it should work.
