Exercise & Fitness Logo
Rob Black Posted on Dec 08, 2017
NordicTrack EXP1000i treadmill powers on but will not work
Hello - I have a NordicTrack EXP1000i treadmill that powers on but the control panel will not respond. The unit worked fine when last used several months ago, but I stored it in my attached garage while I worked on my basement. I moved it back into my basement and...nothing. Any suggestions are greatly appreciated.
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jul 08, 2009
SOURCE: hello nordictrack has just stopped
Sometimes when these machines are assembled
a wiring harness gets damaged. If you have a manual, look at the diagram that shows the upright columns where the upper console mounts.
Look for the wiring harness coming out the top or bottom on the diagram. If it is on the right, the take the screws/bolts out of the arm that mounts to the upright and lift it up, just a little to see if the wiring harness is damaged or partly disconnected. If you cant see anything, then it is time to call a tech out to troubleshoot the problem.
michaelwitt
  • 74 Answers
  • Posted on Aug 29, 2009
SOURCE: I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Anonymous
  • 9 Answers
  • Posted on Oct 22, 2009
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Anonymous
  • 40 Answers
  • Posted on Nov 01, 2009
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Mar 01, 2010
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Our NordicTrack T5 zi treadmill belt is not moving...
Belt Not Moving:
If the belt isn't moving, there are a few potential causes. One common issue is a faulty motor controller. Even if the red LED on the control panel is lit up, it might not be sending voltage to the motor. To check the motor, follow these steps:
First, test the motor using the methods outlined in this guide: Motor Testing. Motor Testing (treadmilldoctor.com)
If the motor is working, the motor control board may be the culprit.
Console Wire Check:
Inspect the console wires that run from the motor board through the primary wire. Loose or damaged wires can cause the belt to stop moving. Reconnect any loose wires.
Smoking Smell:
The smoking smell you noticed could indicate an electrical issue. It's essential to address this promptly.
Off-Center Belt Alignment:
If the belt is off-center, it can cause problems. Confirm that the treadmill is on level ground by using a bubble level. Then, follow these steps for belt alignment: Belt Moves to One Side. How to Fix Treadmill Belt Slipping to One Side ' Stay Centered (treadmilldoctor.com)
Loud Mechanical Sound:
The noise during operation might be due to misalignment or worn components. Inspect the treadmill's moving parts for any signs of wear.
Retirement Decision:
Based on the severity of the issues and potential repair costs, you'll need to decide whether it's worth fixing or if it's time to retire the treadmill.
Professional Inspection:
If you're unsure, consider having a professional technician assess the treadmill.
Nordictrack elite 900 - Does not power on
Sorry to hear that your NordicTrack Elite 900 treadmill stopped working. Here are a few things you can do to troubleshoot the issue:
  1. Check the power source: Make sure the treadmill is plugged into a working electrical outlet and the power cord is securely connected to the treadmill.
  2. Check the circuit breaker: Locate the circuit breaker on the treadmill and make sure it hasn't tripped. If it has, reset it and see if the treadmill powers on.
  3. Check the safety key: If the safety key is not properly inserted or damaged, the treadmill will not power on. Make sure the safety key is securely in place and not damaged.
  4. Check the fuse: Some treadmills have a fuse on the power supply board or control board. You can check the owner's manual to see if your treadmill has a fuse and where it's located. If the fuse is blown, replace it with a new one of the same rating.
  5. Check the motor: If the motor is faulty, the treadmill will not power on. You can use a multimeter to test the continuity of the motor. If the motor is not working, you may need to replace it.
  6. Check the control board: If the control board is not working properly, the treadmill will not power on. You can test the control board with a multimeter to see if it's receiving power and sending signals to other components.
If you're not comfortable troubleshooting these issues on your own, it may be best to contact a professional technician or the manufacturer for assistance.
if u like to tip me https://paypal.me/AymanZiyat ty
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
2answers
Only certain buttons on the NordicTrack exp1000 treadmill work.
1) You must check the flexible cord between display board vs controller motor board, and tight very well
2) Try to access to the keypanel and clean with special spray (clean contact you can find in radio schack or computer store).
3) Try to Measure the +5Vdc for I.C. including EPROM, ROM, etc.
4) And try again.
5) Measure if the power supply to display is coming out from the Lower board or Motor controller board. If not the Motor controller is faulty. You must replace it.
Use Dvoltmeter.
Remember 90% aprx the Motor controller board access to the function in the display board, elevation motor, power input, etc.
sincerely.
2answers
What can be the problem when motor does not start for nordic track model # NTTL9912.0
assuming there is power going to the motor. loose pwer connection or burnt out motor
1helpful
Nordictrac 2500 problem: when dead man key is removed, control panel lights up, but none of the functions work. With he key in place the treadmill functions normally.
You have it in DEMO mode, your manual will show you how to disable this feature.
Have a good new year!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
My Nordictrack treadmill has the electronic panel work, but the motor appears to be not working. Help i am getting fat!
Your treadmills needs a motor controller. It could probably use some belt lubricate also. The heat that's created from the friction of the walking belt and the board under it causes an extra drag on the motor. The control board sends more power to the motor to make up for the loss of speed. This will eventually kill the controller. So lubricating could be a key factor to not damaging a new control board right away. Hopefully this helps.
Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
