SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
SOURCE: beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
SOURCE: beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
SOURCE: My beater bar is not turning so the vaccuum is not
You need to replace the belt, it has probably broken. Your actually supposed to change them yearly. Here is a link to
the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
SOURCE: Right out of the box,
I found the fix for the dc 33. Open up the cover to the beater bar. look at the cover. You will see many small triangles. Look very closely for a small rubber strip that runs along the edge where the triangles are. It is kinda hard to see. Once you find it remove it. Now on the vacuum itself there is another strip. This strip is very similar but a little longer. Remove that strip. No more **** noise whalla. The perfect Dyson!
