I would like to remove the crank from my K2 Razorback in order to change the gears. Which tool should I use that fit with this crank model?
Mario, there are two type of cranks that you could have. The first is held on by a bolt in the center of your crank, the second type has bolts holding on the crank arm on the non-drive side and the whole thing slips out of the bottom bracket bearings. If you have the older style with the bolt in the center of the crankset you will need a 14 or 15mm socket wrench and a crank puller. The crank puller will thread in to the crank and a center "driver" is then turned in against the bottom bracket to remove the crank arm.
You can remove the rings with out taking the crank set off, however. The hard part about that is holding the back side of the chain ring bolts so they don't spin while you try to loosen them. There is a handy little tool made for that, too.
SOURCE: I am looking for the
Try contacting K2 directly.
http://www.eccyclesupply.com/k2bikes/index.php?page=contact
