SOURCE: Sansui amp problem
This sounds like you lost the 5V supply. If you can solder, look for bad solder connections around the voltage regulator ICs. These look like transistors (3 legs) and may be attached to a heatsink. They will be marked 7805 +/or 7905.
Dan
SOURCE: NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
