When I plug into either HDMI part there is no picture. I have one HDMI cable that when I moved it around a little a picture would briefly appear on both ports. I have tried 5 different cables & no picture. I think there is a loose connection or a short.
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
