Hello there feel to explain everything that happened we would put too will explain in words ...
I bought a Garmin Nuvi 205 navigator, I have attached to the PC to charge the battery but I accidentally formatted ...
Now how do I make it work?
I used the driver suitable aiutooooooooo
Hi, I unfortunately formatted my sat nav. now I have no pre loaded maps installed on the device, is there any way I can get uk/and Ireland maps loaded back on to my sat nav.? Any help and advice would be appreciated. Many Thanks. Regards John ==
You have not only erased all of your maps but you have also erased all of the internal software that was a part of your Garmin. I do not recall seeing anything on the web site that resolves your issue. If you can get a hold of another 205 perhaps you can make an image file of its software and then transfer that over to yours.
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
SOURCE: My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
First you will want to empty your recycling bin & clear your
temporary internet files before re-downloading the Garmin_RMU_2010B.exe
file.
Below is the remainder of the fix I received from Garmin support
and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the
end of setup.exe". For example the end would look like xxx\Setup.exe"
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be
built. Leave the Window open till completion of all steps. 9a. Windows
XP: Click on Start>Run, then type in %Temp%. Another window will
open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder
on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin
folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have
any trouble with this fix, or are not comfortable trying it please call
our Software Support Department at 1-800-800-1020. Please be at a
computer that has high speed internet access as we may need to log on
to your computer to resolve the issue. Make sure you have the program
extracted using the 7 zip program provided above. Hours of Operation
Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
SOURCE: Garmin Nuvi 255 w manual
Enjoy...
https://buy.garmin.com/shop/store/manual.jsp?product=010-00718-20&cID=134&pID=13431
no. 5 and 6 are what you want.
Please Rate if you found the above info useful. And please give feedback if you got what you wanted. Your feedback is very important to me. :-)
SOURCE: Garmin nuvi 610
https://buy.garmin.com/shop/buymaps.do
Garmin offer new maps, the majority in different formats such as online downloads, pre-loaded SD cards, or on DVD.
However, these are pretty costly for all they are worth. For the same price as a map, you could easily buy a brand new device with full EU maps.
