Hi,i can't block incoming phone calls on my nokia lumia 610,could anybody help please,i'm getting loads of annoying calls
SOURCE: blocking calls, motorola razr v3
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls
From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts
SOURCE: how to block unknown incoming Calls for nokia 7310
hey i think your phone have no features that only the no.in your phonebook can be accepted, you can do only is block all incoming calls, but try to look at the call settings.
SOURCE: Incoming call blocking
the call must be blocked from the tower in order for your phone not to react to a connection attempt from that particular mobile device number. you can contact your service provider and they may have a work-around or a fix for you.
the easy way though, and the way i recommend as long as you are wanting to block calls and not txt from this number, is to asign a custom ringer as none. this will silence your device and deactivate the vibrate mechanism.
now when that # dials yours, you are not disturbed.
or if ur realy serious just call ur service provider and they can fix u up.
pls rate this fix
SOURCE: Nokia 1100 Closed User Group
Contact your service provider cutomer care number they will help you
SOURCE: hi i want to block
Greetings,
In order to block calls from a particular number you need to contact your service provider. You can dial 611 usually. They can put a block on that number for you, just let them know if you are getting harrassing calls, etc.
Thank you.
