Hooking up speakers is easy you if your terminals are red and black you just match them up black on speaker means hook to black on the receiver doing a wrong hookup can reverse the phase of the speaker cause a distortion and eventual damage to speaker and coil.if you are rtunning just a stereo that allows two speakers select speaker you want for left side and put that on left of the stereo and hook it up as left and same for the right and if you have a home theater you hook it all up the same but you hook up the center put it in center front of the room as far back to wall as you can but dnt cover it up it should be lower than the front left and right or the main left and right speakers.then if the5re is surround you put those like say you have a square room you put them in the corners on the back wall.if you have rear speakers you put them on the back wall.make sure all speakers excepty rthe center are level and equal distance apart
SOURCE: Can I hook up a
First of all, here is the main ONLINE SUPPORT page for your model:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v493_black__u/?mode=model
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V393.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
You should just be able to use the TAPE REC AUDIO OUT (L/R) jacks on the back of the Yamaha 493 unit as your secondary amp's input signal. You might even be able to use the VCR AUDIO OUT (L/R) jacks as well. See page 8 of the manual for a detailed diagram of the rear connections on your set.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
SOURCE: I don't know how to
Some make/model information might help us/you find the manuals.
Generally, Line Level OUTs to Line Level INs; and PHONO only goes to PHONO unless there is a PHONO preamp somewhere in-line with it (sometimes built-in to newer turntables).
Start surfing for the manuals if you don't have them.
You might find it them the manufacturer's support site, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
SOURCE: I've got a kr-a4020 am/fm
Hi!
When connecting some speakers to an amplifier the first important thing is the impedance. This is in your receiver 4 ohm for each speaker (the impedance is written on the back pannel of your receiver). Using a lower impedance for the speaker can and will harm the receiver.
The second important thing is to use speakers with a rated power no LESS then the receivers rated output power. In your case it means no LESS than 100 W. Using speakers with a higher rated power does not any harm to the receiver, it means only that the speakers are able to handle the power delivered by the receiver or even more without any danger to get the magnetic coils inside the speakers burned.
Regards,
Bogdan
