I have a sidekick 3 and when i stop using it for a long time and i used the sim in another phone and now that i try to us and connect it again it tells me to wait for activation and it tells me to wait for at least 48 hour i do wait for 48 hours and nothing happendes
I use a sidekick Lx for At&t that I unlocked myself. When you start up your sidekick it should ask you for a network unlock or ask you to enable your sim card just click the cancel key on the top right of your device. Now click the top left menu button and go into your settings, and go to 'sim center' it'll ask you to enable your sim card again just enter a random 4 digit number and it'll tell you its wrong but thats ok, click ok and just cancel it out :) it'll then show you "disable sim lock" "change sim pin" change your sim pin to a number you'll remember because the way im showing you you'll have to do this every time you restart your phone (my sim pin was by default 1111) you can enter the same pin number for the old sim pin, and new sim pin options. Once you do that a white phone icon should appear on your screen underneath your time and date. Now, go back into your settings and go to network options, scan and select your network manually, and there you go :) Sorry though with all unlocked phones you'll only be able to make calls and text. No picture messaging sadly :( You need a T-mobile sidekick plan for all that :(
So an unlocked Sidekick on ATT will only be able to do text and phone. The other sidekick features require the t-mobiles sidekick data plan. It is hard coded to the phone
You can bypass the activation screen by pressing "Menu" (the key with the 3 horizontal lines) and "L" - but you will need to do this every time you turn it on.
The only permanent way of getting rid of that screen is to actually activate it - and this needs a T-Mobile SIM with the sidekick service provisioned on it, and will have the effect of locking your device ID to the account of the person who's SIM you used, which might cause problems if you ever want to use the phone on T-Mobile later.
not sure if this works with the 2008 but its something you can try, i put a sim card in my LX and was asking for a special code to unlock the phone, well right now tmobile isn't unlocking the sidekick, but you can trick the phone into using the sim card. First go to your settings, go to "SIM Center" and click on disable sim lock, enter in whatever your sim password is (if you dont know your sim password get your PUK (pin unblocking key) number which customer service will give you if you call 611, you can change that SIM pin by typing **05*PUKnumber*newpin*newpin#) now if you wanted to change it to "0123" if your puk was 9483992 its 7-9 digits you would type **05*9483992*0123*0123# now your sim pin is 0123. (trying not to make this super complicated) it will say sim pin not accepted click ok, now click change sim pin you can type the same sim pin 3 times if you want, 0123 0123 0123 now at the top of the screen bars will show up with a white phone beside it, go to Settings-Network Options-Scan and Select Manually, the SIM network should come up, click ok when it finds it and it will connect, now you can call and text on whatever sim you have in the phone
Hi my name is femi, am from nigeria... i have a tmobile sidekick3, any time i on it, it has for code to unlock device...but when i insert sim it has for code to use the t-mobile service..have bein trying to unlock the phone but i dont get the code. i will be glad if my problem can be solve.....my email is...femifamous2007@yahoo;com.......... wating to here from you asap... am still wating to here from you cos i need it now.....
1. Insert your non-TMobile sim card 2. The phone display says "Enter the code". 3. On your Sidkick, press the "X" button. 4. You will see the menu. 5. Choose the left-up angle button. 6. Choose "setting"--->"network"--->"scan and select manually". 7. The phone will search for your network. 8. When your Sidekick finds your network, you can use the phone to make calls
with other sim cards you cant use data services...t-mobile uses different type of connection from other companies
