SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
SOURCE: receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
