I have a 2012 f150. the climate control module quit working. all lights work. air only out floor. replaced module with used one, works the same. Ideas?
Taking the vehicle to ford an having the modual programmed . You can't just replace these modules . Give them the old one ,check for DTC'S - diagnostic trouble code's . Nothing you can or should do.
NOTE: Some PCM DTCs may inhibit A/C operation. If any PCM DTCs are retreived, diagnose those first. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
DTC
Description
Action to Take
B1003
Mode Door Short/Failure
Go To Pinpoint Test F .
B1200
Stuck Button
Button held too long may set DTC. ATTEMPT to clean buttons. If code returns, INSTALL a new electronic automatic temperature control (EATC) module. REFER to Section 412-01 .
B1251
In-Vehicle Temperature Sensor Open Circuit
Go To Pinpoint Test A .
B1253
In-Vehicle Temperature Sensor Circuit Short to Ground
B1255
Ambient Temperature Sensor Open Circuit
Go To Pinpoint Test B .
B1257
Ambient Temperature Sensor Circuit Short to Ground
B1342
EATC Module Faulted
INSTALL a new EATC module. REFER to Section 412-01 .
B1676
Battery Voltage Out of Range
Go To Pinpoint Test Q .
B2266
LH Blend Door Failure or Short
For vehicles not equipped with electric heater, Go To Pinpoint Test K .
For vehicles equipped with electric heater, Go To Pinpoint Test L .
B2267
RH Blend Door Failure or Short
B2268
Steering Wheel Control Switch Circuit Open
Go To Pinpoint Test D .
B2269
Steering Wheel Control Switch Circuit Short to Ground
B2426
RH A/C Solar Radiation Sensor Open Circuit
Go To Pinpoint Test C .
B2427
RH A/C Solar Radiation Sensor Circuit Short to Ground
B2795
LH A/C Solar Radiation Sensor Circuit Short to Ground
B2796
LH A/C Solar Radiation Sensor Open Circuit
U2050
No Application Present
All Other DTCs
REFER to the Master DTC Chart in Section 419-10 .
