I have a coleman powermate 5000 genertor w/a subaru engine.
After I start it ; it will run 20 to 30 minute. Engine die out. Then I will start it right back up and it will run for 10 to 15 minute. Then it will die out. This will gone. help.
Re: I have a coleman powermate 5000 genertor w/a subaru...
Try removing the float bowl from the carbuerator and empty it out. Also check the float valve to see if there is debris under it. Thi problem is definitely fuel.
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
? 4:35 https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
You need a quart of regular old SAE 5W30 motor oil with detergent. The engines on these generators are more or less the same as a lawn mower. Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Hi, Have you checked the oil? Check it when it is warm as this gen set has an oil and overtemp cutoff.
