Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
This has a digital reverb unit. The settings are subject to get clobbered I suspect. I don't know if you are using foot switch for the reveb control... You may also have a cable that has come loose...
Notice that the reverb is set by DC voltages from teh setting pots that go to the DSP chip. These setting pots receive voltage from a 16 volt ZENER regulated source. First thing is to CHECK that voltage. If the Zener has opened and you find much over that 16 volts, that is your cause of the problem.
The circuitry is on page 1 in the 3B to 3D lower left of the page.
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Could be a loose connection inside the amp (such as a wire), a bad component, or a severed ground. Many possibilities here. If you know electronics, take a multimeter and start testing all the components. Look for any burn marks, check for broken solder connections, and continuity test all wires. Be careful since amps can hold a deadly voltage for a good while. Be sure to drain the capacitors before doing anything else inside it. If you do not feel comfortable doing this, you can take it to a electronics repair person. Keep in mind that Crate is one of the harder amps to fix because most of their components are surface mount.
Check the input RCA plug going into the reverb tank (silver box with two wires connected to it). Make sure the amp is off when you do this. Sounds like the output is working fine if hitting the amp does it.
