Turn off radio and hold mode button to see if you can set clock that way. I know you have to do that on some older radios like pioneer and sony. If you give me the Xtreme web site you have I will try to help you more.
Good Luck
Hold down "disp' button until it flashes and then press tune up for min and tune down for hours
Unfortunately there is no info on that stereo.
did you try holding down the display button while the clock is on the screen. or try holding down the menu button while the clock is on the screen. and try try holding both down at the same time.
if these don't work please let me know what buttons are on the front of the cd player so that i may better assist you.
best of luck.
please remember to rate me.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Follow the steps :-
1. Turn off your CD player.
2. Press the "A" or "Audio' button on the CD player Until the clock display hours area begin to flash.
3. Use the up and down arrows to select the proper hour.
4. Press the right arrow button to make the minutes of the clock display flash.
5. Use the up and down arrows to select the proper minutes for the clock.
6. Press the "A" or "Audio" button again until the clock display stops flashing. Your clock will be set, and you can turn your Xtreme sound WMS336 CD player back on.
Thanks for Using Fixya.
Do rate the solution and God Bless you.
Remove the unit, unplug all cables, then remove the watch battery inside the unit, this will then reset the unit then plug it all back in and place battery back inside and it wil take you through the setup again.
hope this helps
alex
1 Press FUNCTION to select clock.
2 Press c or d to select the segment you
wish to set.
Day—Month—Year—Hour—Minute
As you select segments of the clock display
the segment selected will blink.
from manual
Pull clock up hold mode and select button till time flashes use tuner buttons to go up or down then sel to change between hours and minutes hope this helps
if mode and sel didnt try mode and dis if you get frustrated just unplug fuse at 11:59 or 12:59 depending if radio starts at 12 or 1 and your time will be right im sure your getting frustrated ive seen what answers you have gotten the other option i would suggest is to go where you bought it or call make them give you either instructions or explain it to you is there a company or manufacturer name you could supply and i would be happy to get a pdf for the car audio
here is a support link it is incredible hard to find the manufacture try this hope it helpshttp://www.monstercable.com/service/
Just press on the time buton and hold down on the set buton and change it whit the fowar or back wasd skip button
http://www.barinas.com/AN-Xtreme%20Man.pdf
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
As i think in this case contacting the manufacter servi center is much needed as they can porovide the manual with exact instructions. contact near by dealer .
Just hold down the clock button and press 1 for hours and 2 for minutes.
also read this
Set Time and Date
1. Press the EDIT button, then the TIME/DATE button. These buttons are located on the back of the
remote. Use a paperclip or similar tool to press these buttons. The display on the front of the
remote shows SET HOUR.
2. Press VOLUME+ or VOLUME- to select the hour. The remote cycles through a 12 hour clock (AM
and PM) and then a 24 hour clock. A PM shows on the display for PM times. There is no display for
AM.
3. Press CH+ and the VOLUME buttons to set the minutes, date, year, and day.
4. Wait a few moments and the remote returns automatically to its normal mode.
Here is the manual for the system, however it does not mention any option to set up the time.
The manufacturer website was http://www.xtremeproducts.com/, but it appear to be closed.
I think this is real manufacturer website, the other one was just a distributor.
They do not provide any manual download, all you can do is contacting them to find out how to correct the date time.
If that is the product, then Here is the manual.
The manual was for an home wireless unit composed of a CD and a set of wireless speaker, not a car stereo.
By the way you should contact the manufacturer the same, this product is not very common on the market, and that is the only way to get support.
Pls tell me the brand name
Setting the date and clock
Use these instructions to set the clock.
wish to set.
Press the menu button and keeping it pressed.press volume button up and volume down alternately 5 times to reset.
as you will have to contact the near by dealer for this because they mostly have the manuals for this and also provide.as they them self sell this product.because the online manual provided by the company is not providing this time and date setting.its just showing up the feauters in the unit.how to place and some common things which we all mostly know.
as contacting the manufactres website or local dealer will be much more helpful.
thanks.
HI,
I'll let you know if there is a user manual available for this model in a moment.
Hi!
You can go to menu>settings>time and date and from there you can change the time of the day on your CD player
Please press the "DSP button" until the Clock flashes, then press the volume up for hour setting and press volume down for minutes settings and then save it.
Thanks
Rylee
Thanks
Rylee
I have been unable to locate a web site for the manufacturer of this deck, the company sells through Wallmart so u should be able to get tech support information from wallmart.
my stereo has no button for menu. It has a mode button which does not access any menu. If you need serial # on my unit is 2309055812.
I must leave for a few hours so don't panic if you don't hear from me for 5 -6 hours. Thank You. Bob
hello - I am back and awaiting your reply. I hope you can find an owners manual or an answer to my question so I can get you paid.
Bob
The website is under Xtreme cd players, but I did not find any downloads for instruction manuals. The unit works great, just can't find how to set to correct time. Sorry to be so picky, but it is not worth it to accept and pay for no solution. I hope you can help me. Bob
there is no menu button
there is no function key
turned off radio - holding mode button merely turns radio on. I thank you all for your trying to help, but I am going offline.
PS - radio has customer assistance # 1-800-763-8340 which I have been calling forever with a constant busy signal, hence my trying you guys. Again sorry and thanks.
Goodnight
brand name is Xtreme sound model # WMS336 CD Player
okay I guess we'll have to say we don't know the answer. FYI there is no dsp button..I have pushed & prodded all the various buttons, both on and off, to no avail. To keep from getting answers that involve directions that can not be followed I will recap all the buttons on my unit: open--mode--sel--p-eq--disp--1pau--2scn--3prpt--4shf--5--6--ams--power--mono--bnd/low--lo--mu--tune/track. I have tried all these buttons with unit both on and off and get nothing about setting clock. As to date I don't think that is an option, as only time displays, at least I think it is time as it changes by the minute. Hope this helps.
Thank you for the manual, but it is for a home unit not a car stereo. I guess I will have to resign myself to the clock not being able to be set.
Somehow you guys are not reading my entire posts. There is no edit button or time/date button! Thanks again but I think we'll have to give up on this one!
am I supposed to accept even though no solution to my problem? The contact your dealer/factory was tried long before I first contacted you guys. Pay anyway? It said in your ad satisfaction guaranteed.
It does not - this is the second sending of this manual for a HOME CD system. Mine is a car audio system. Thanks again for trying!
Thanks but none of these buttons exist on my system. I have posted complete info on prior posts. Thank you anyhow!
thanks for the suggestion, but nothing happens when I do this.
Thanks but please read my entire conversation - you will note there is no function button. Thanks again.
thank you but there is no watch battery. I am just going to buy a new unit.
thaqnk you - there is no a or audio button. I am just going to buy a new unit.
one more time - there is noA button. Thanks again.
