Jacuzzi LXS6030 WRL 2HX A 60" x 30" Luxura Three Wall Alcove Comfort W Logo
Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does jacuzzi luxura have a built in timer - Jacuzzi LXS6030 WRL 2HX A 60" x 30" Luxura Three Wall Alcove Comfort W
US Parts Center
Level 3:
  • Jacuzzi Master 719 Answers
  • Posted on Mar 29, 2013
US Parts Center
Jacuzzi Master
Level 3:
Answers
719
Questions
0
Helped
284117
Points
1972
If your model has an electronic control then it will have a built it timer program.
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Does the pump on my motor have a reset button
There are no reset buttons on motors.
How do you turn the pump on/off ?
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Jacuzzi will only run for 4 hours cuts off and will not cut back on.
I am supprised that it will run that long. Most of them have a safety timer built in so that you will not get hypothermia.
What do the arrows on the jacuzzi luxura 530 control
Arrows on the control indicate up/down temperature or on/off on the air control.
2answers
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
1helpful
I would like to install a Pass & Seymour RT1 Timer for my jacuzzi tub. 2 gang box contains white and black wires for the GFCI and white and black wires to the tub. how do I make this connection
I answer questions for free.
I specialize in timers and electrical devices.
My answer might ask for more information, and you can add a comment and we can go further.
The RT1 is a digital countdown timer rated for 120Volt 600 watts.
1) You need to consider the wattage of your jacuzzi circuit.
If circuit operates a motor, then check the nameplate on that motor for wattage.
The RT1 is too lightweight for 756Watt 1HP motor.
The RT1 will not work on a 240Volt circuit.
If the circuit operates lights only, then add up the wattage of your bulbs.
The Pass-Seymour site does not have a manual for the product that describes the intended purpose of the timer. For example some timers say 'incandescent only.'
2) Understand your wiring so we can get a timer that works:
You have a 2 gang box.
The box has a GFCI and no other device.
The GFCI has 4 screws
One cable enters box from breaker box with black and white ... and these wires connect to GFCI
One cable enters box from jacuzzi with black and white ... and these wires connect to GFCI
3) If the circuit is 120V.
Next we are going to talk about the cable going to jacuzzi.
Disconnect black wire going to jacuzzi.
Timer-black connects where this wire was connected.
Timer-red wire connects to black wire going to jacuzzi
The timer-white connects to the same screw that white-wire-going-to-jacuzzi connects to.
So there are two white wires on one screw.
If RT1 is too lightweight
You need a countdown timer rated for the circuit.
Intermatic makes a spring-wound FD series countdown timer that is rated for 2 HP
The Intermatic FD series timers can also be used if jacuzzi is 240Volt
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Add a comment, and I will help with more detailed information how to connect the FD series timers and answer any question about the FD.
Inead a new timer for a jacuzzi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First thing:
Determine Hp (horsepower), wattage and volts. There is a label that shows these values
1) Indoor Jacuzzi pumps are usually 115Volt and 1 Hp to 1.5 Hp. 1 Hp or horsepower is 746 Watt, 1.5 Hp is 1119 Watts
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Which timer? If wiring is already connected to a switch, ordinary in-wall 15Amp timer can handle up to 1400 Watts.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2) Outdoor Jacuzzi or Hot Tub pumps can be 115Volt or 240Volt and up to 5 Hp. 5 Hp is 3730 Watts
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
