Dell Photo 964 All-In-One InkJet Printer Logo
Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New dell printer 926 does not feed paper need repair manual
Looking for copy of repair manual PDF or instructions on how to check or adj the feed mech of this printer - it fails to grab paper if i puch the paper deeper into slot it will grap and print ?
  • tonymarana Feb 27, 2009
    thanks - no warrenty - new? in box from local yard sale - so??
    anyone know why paper is not being feed - i can push paper down as it trys to feed and it will catch and print - I looked at first set of rollers and they do not seem to move (roll) when i hear the hum of feed ... must be a gear or belt not giving drive to this first set of rollers??
john smith
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 132 Answers
  • Posted on Aug 08, 2017
john smith
Expert
Level 2:
New Friend:
Cheetah:
Answers
132
Questions
0
Helped
133835
Points
419
If you want technical support of Dell, you can contact us on Dell Printer Customer Service Phone Number 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/jBhoUv
Smithmkt
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Expert 68 Answers
  • Posted on Jul 22, 2017
Smithmkt
Expert
Level 2:
Filmmaker:
New Friend:
Answers
68
Questions
20
Helped
51444
Points
426
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 27, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
2703
Points
15
Is it under warrenty? contact the vender if it is as you may void the warrenty if you try to fix it yourself
I need a owners manual for my printer.
Hello, I've had a look on the Dell support website and there's a copy there, though you will need to unzip it so will need winzip or similar.
The link to the file plus download instructions is at the following address which you can either paste into your web browser or 'right-click' on and select 'open link in new tab' to access.
Regards, Nicam49
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
3answers
Dell photo 926 printer
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
1helpful
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dell 926 all-one inkjet printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
