Pool & Spa Logo
Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiring diagram for ff32atc control box
Hot tub under water no power to pump and heater
US Parts Center
Level 3:
  • Master 719 Answers
  • Posted on Mar 19, 2013
US Parts Center
Master
Level 3:
Answers
719
Questions
0
Helped
284289
Points
1972
If your hot tub has been submersed by water then you are going to need all new controls for it.
NEW control box with a new topside, New motor and whatever else is electrical under the skirt of the tub.
Start your search by getting the brand name and model number off each item.
Rod
US Parts Center
888-521-6183
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Bought hot tub used need to know what size supply wiring and breaker I need
Check your heater/pump/lights/accessories. These should all have electrical ratings. Your supply wire should be large enough to carry the combined amperage of everything running together. I personally would separate each system in the breaker box, 1 for pump, 1 for heater, 1 for accessories.
Apr 09, 2013 • Pool & Spa
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
4helpful
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
What power do I need to get to the hot tub?
You will need to check on the control box under the hot tub. Most tubs can be wired ether way. Others no. If it can be wired ether way 220v runs cheaper and will heat the water a lot faster. But you will have to check on the face or door of the control box. I had a 110v outlet by mine then found it only runs on 220v. It cost me to run the 220v but I'm glad I did, it heats from 75 to 100 in less than an hour. Less run time and less power when it runs.
Oct 20, 2010 • Pool & Spa
1helpful
I have a 2000 Sovereign Hot Spring hot tub that quite heating, I checked filters they are ok, I have no air lock, The jets and light work fine. Inside the control box on the circuit board all 3 led lights...
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
2answers
Hot tub blows 50 amp breaker after about two seconds-does move water. about half full of water, bought tub used and sat for a year empty
I think you have a small leak somewhere that is causing the GFI to kick off. ... and it is probably quicker than 2 seconds.
Look carefully inside the control box - that is where I found the leak in mine.
After you get it fixed (and you may have to buy a new control) pat yourself on the back for having saved yourself at least $250.00.
Good luck with your project.
a
Oct 14, 2009 • Pool & Spa
How long does it take to heat the tub
Make sure that the inline heater has power. It should not take very long to heat since your putting hot water into it anyway. The heater is to keep water warm.
1helpful
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
