Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
Pitch drifts px 330
The pitch will correct for a time then drifts ...but not in steps or half steps. pitch error amount can be up to 3 notes
    Sergeant:
  • 336 Answers
If anyone using a wireless guitar setup is close to it when playing, can do that.
Posted on Mar 20, 2013
  • Tom Dukes Nov 20, 2013
    I have a similar problem with the Casio PX-330. When I first power on, it is almost a whole step flat from A440. I can compensate by transposing +2 and tuning -33, but it still drifts around a bit over time although it seems to always be in tune with itself. I sent an email to Casio support a long time ago, but never heard back.
  • Kevin Haymon
    Kevin Haymon Feb 28, 2014
    having same issue...my keyboard is about 2 years old....is there an internal battery that is getting weak?
SOURCE:
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
Aug 22, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Casio px-330bk keys pitch sharp top half of keyboard
The problem you're encountering is actually a feature, called stretch tuning. While real pianos are tuned in this way it's meant to sympathise with their natural 'organics' and might sound wrong on a digital instrument. The solution is to turn stretch tuning off. The manual should be able to tell you how.
Jun 15, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Is there an internal reset for my privia 330?
to do a factory reset you Turn the Keyboard off the press and HOLD TONE AND FUNCTION and power the keyboard on while holding them buttons. if you did it right you'll see some wierd start up and flashes and then everything will be back to normal. try a few times if at first it doesn't work. somtimes it's picky.
Oct 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Can i tune the privia 130
Refer to page E22 in your user manual. Please note that the default pitch is crystal controlled and quite accurate, but if you need to detune it you can do so as well as changing the temperment.
Jul 03, 2011 | Casio PX 130 Privia 88 Key Digital...
My Casio Px 330 keyboard is about 1.5 years old. After the instrument has been played for 20 minutes or so, one note (D above middle C) sounds very loud regardless of how hard it is struck. The problem...
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
Jun 02, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
108 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
