Cars & Trucks Logo
Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver's side low-beam headlight out
What are the steps to replacing (low-beam) headlight bulbs on a
2008 Mercedes CLK cabrio.
Anonymous
Level 3:
  • Master 580 Answers
  • Posted on Jul 11, 2009
Anonymous
Master
Level 3:
Answers
580
Questions
0
Helped
316836
Points
1652
Purchase the correct bulb, open your hood, unscrew the white retaining ring behind the non working lamp when loose turn black connection 1/4 turn counter clockwise till tabs line up pull straight back remove old bulb put on rubber gloves or BE CAUTIOUS NOT TO TOUCH NEW BULB GLASS WITH BARE FINGERS. Oils from your hands an cause bulb to heat unevenly and cause new bulb to explode in the headlight assembly
So with gloved hands open new bulb insert follow steps in reverse to reassemble. Happy Motoring
1995 Mercedes e 320 driver side headlight stopped working. Bulb is good
Solution: If both headlights aren't working, it's unlikely that a bulb is at fault. The likely cause is a fuse, headlight relay, headlight switch, dimmer switch or a wiring fault. ... Consult your owner's manual to locate the main fuse for the headlight circuit and replace that fuse with one having the same amp rating.
OR
Most total headlight failures are caused by a bad component like a fuse, relay, or module. Wiring problems can also cause both headlights to stop working. High beam headlights don't work or low beams don't work. The cause: A burned out bulb, or a problem with the high beam switch or relay.
https://www.lifewire.com/fix-non-working-headlights-4137021
Where is the fuse for the low beam for a 2005 clk 320
there should have a fuse layout or description in the fuse compartment near or under the light switch.
10helpful
How do i replace the low beam headlamp on a 2008 mercedes?
Under the hood, there are two round head lamp covers on each side. One for high beam and one for low beams. The low beam is the outer cover. Turn this cover counter clockwise and remove. This will expose the back of the bulb. There is a small clip holding the bulb into the headlight housing, but you must unplug the light before removing clip. Once you have unplugged the light, the small metal clip can now be undone. on the side opposite the hinge, push the clip in towards the casing and then to one side (which way to push depends on which light it is.) Then the clip will release. you can now remove the bulb. place new bulb in and make sure it securely fits into position. reinstall the clip and reconnect the power. check for propeer function of the lamp before replaceing the cover. Once you confirm lamp is working replace cover and you are done.
This is easiest to see on the passanger side light. The driver side is slightly more cramped.
Need to replace headlight bulb 2007 hhr
H13 HALOGEN HEADLIGHT BULB, SOLD INDIVIDUALLY -- Low 55/high 65-watt halogen bulb; 12.8 volts; P26.4t base; A high quality, direct fit OE replacement headlight bulb
How to Replace a Headlight Bulb
(DIY Complexity: Easy / Time: 0.9 hour)
Parts:
1. Headlight Bulb
Tools:
1. Screwdriver
2. 1/4 in. Drive Ratchet
3. Socket Set
Steps:
Step 1 Open the hood and locate the headlight assembly.
o Tip: Most headlight assemblies have a place in the rear to gain access to the headlight bulb.
o Tip: It is recommended that headlight bulbs are replaced in pairs.
o Tip: Always make sure the struts on the hood can fully support the weight of the hood so that it does not close on you while working. The use of a hood prop can securely hold it in place.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Gain access to headlight bulb.
o Tip: It is a good idea to check the high beam and low beam headlight bulbs at this time.
Step 3 Disconnect the wiring harness and replace the old headlight bulb with a new one.
Step 4 Turn on the headlights and check high and low beams to verify repairs.
Hope this help (remember rated this help). Good luck.
4helpful
Can I adjust the direction of the headlamp beams? They do not appear correctly aligned.
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
7helpful
2answers
Headlight repair on 2003 Mercedes Benz E320
how do you change left low beam bulb on 2003 mercedes e320
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
