Question about LawMate PV-RC200 HD Keychain Video Recorder
When turned on the blue light continues to flash
Bush tv 3 weeks old, tried turn it on but just a black screen,standby light turns blue as if it's on also if I press any buttons on it the blue light flashes like working but just a black screen
Here goes:
#Press and hold the on/ off button...
#Whilst holding unplug the plug from the wall...
#Continue holding for 30 seconds...
#Plug in the plug whilst continuing to hold the on/ off button...
#Continue to hold for a further 30 seconds...
And the screen should come back on!
Jul 23, 2016 | Bush Televison & Video
Continuous Blue Light Flashing, Mistubishi LT-52244
Try unplugging for 1 minute, then plug back in again. It appears that the unit is initializing, if it continues in that mode you may need the DM PCB
part# 921C549008
see the following website:
http://www.shopjimmy.com/catalogsearch/result/?q=921C549008
Jun 17, 2014 | Mitsubishi LT-52244 TV
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
VL1919 blue light flashes continuously, monitor does not turn on. . . even after DAYS of flashing. : (
That is the problem with the standby section of the power supply. A continuous flashing indicate a shorted component usually a small diode.
May 24, 2011 | Princeton Digital VL1916 19" LCD Monitor
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Printer will not print - says check photo tray etc, but ok.
When you see the blue light flashing contineously inside the printer.. it means that it needs technical services... theres no way that you can fix it by yourself... go directly to its legal service center or if it still has the warranty... avail of this..
May 23, 2010 | HP Photosmart C7180 All-In-One InkJet...
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
LawMate PV-RC200 HD Keychain Video Recorder Logo
76 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
