It means that the laser beam of your printer is not detected.
Try to change the printer toner.
***If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
SOURCE: HP Laserjet 4250n printer error 59.00
Replace the main motor assembly. A qualified tech will need to do this.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
SOURCE: no power on hp color laserjet 5550
here http://www.generalmanual.com/Printers/HP-Color-LaserJet-5550dn-Printer.htm
you can download this is printer user's guide (under "download now" near the bottom of the page) help you.
SOURCE: my laserjet p4014n keeps giving me a 51.10 error
it means that the laser beam is not detected.
Try to change the toner.
