In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
What if the carb is leaking fuel out of the carb throat? Both lower gaskets on my Toro 521 snowthrower's engine (I think it's an HSSK55) are fine, and I have replaced the float, thinking it was full of gas and sinking. It's almost as though the needle valve that controls gas flow into the float bowl isn't closing, and the bowl is over filling right into the carb throat. If I leave gas in it and the gas valve open for more than a day, the fuel tank empties due to this weirdness. I can get it to run, barely, only if I shut the valve off between runs. Any possible advice? This carb had never been disassembled until it started doing this.
Also, can someone help me figure out why this engine won't run with the throttle lever in the LOW setting? If I put the lever there, it just stalls, no matter how I clean or adjust the low-speed mixture screw.
The filter was soaked in oil and it will run without the filter on but it still leaks oil.
