SOURCE: Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: Maytag gemini gas stove. Ignitor problems
My experience with this is that it occurs when moisture gets into the ignitor area and shorts out the open and causes the spark. It stops after it drys out.
This is very non-techinical and I will defer if there is a deeper solution.
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
SOURCE: Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
