SOURCE: how do i pair my iphone to my netgear router? the
Are you trying to connect WIFI? "pairing" is a bluetooth function. If the router has not already been configured for WIFI, then your iphone should see a local wireless network called Netgear. You should be able to connect to it with your iphone simply by selecting it and answering the security question. If it has already been configured, you should make sure it was setup for WPA or WPA2 (NOT WEP) When it was configured, it should have been setup with a passphrase (key code, encryption key) which you need to intially provide on your iphone to make the connection. Its pretty straight forward.
SOURCE: I have an optus netgear
First, if you do not have the manual for the Netgear, then download this manual from this WEB site :-
http://kbserver.netgear.com/pdf/dg834_g_b_manual_v2.pdf
Then connect this ADSL modem wireless router to your phone line. Don't forget to install the line filters as per fig 3.5 in the manual.
Then connect the LAN cable to the Netgear as per figure 3.6
Then login to the router and configure the router with the Bigpond ISP settings.
To secure your wireless network from unauthorised access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
If you still have problems, please get back to me with details up to where you were having the problem and the error messages.
SOURCE: I have a Netgear DG834GU
Press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
Use this method for cases when the administration password or IP address is not known. These steps restores the router setting to factory defaults. (e.i. administration password to admin and the IP address to 10.0.0.2.
eds6524
