Mio Go Pedometer Watch Arctic Logo
A
Anonymous Posted on Mar 18, 2013
Mio Go Watch manual - Mio Go Pedometer Watch Arctic
I have a Mio Stride Petite and the vinyl watch band has broken. Can it be replaced?? I love my watch and wear it all the time.
https://www.amazon.com/Stride-Heart-Rate-Monitor-Watch/dp/B001KYEYZW/ref=cm_cr_arp_d_product_top?ie=UTF8
Mar 09, 2020 • Mio Watches
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
Msw-26p3c2l3 manual
how do you get the battery out to change it?
Getting heart rate on mio petite
Is your heart working? Sorry, bad joke. The only thing besides the watch malfunctioning is that you need to have your hand and arm relaxed when you touch the watch case. Apparently if your muscles are tense it can cause the monitor to not read.
1helpful
Changed battery, now buttons on sides do not work, where to get it repaired?
mcdevito75 here, Most likely during the battery change you moved the quartz movement away from the contact buttons. Re-Open your watch carefully and make sure when you press the buttons, each button is pressing against it"s spot on the quartz movement.
MIO MOTIVA STRAPLESS - My problem is that the watch is brand new out of the box, but the actual top right button (Start/Stop/-) doesn't work. Also the actaual sensors don't seem to be picking up my pulse...
Unfortunately MIO do not have repair services in Australia, probably would have to send it back to the US. Hopefully you can work with the seller to fix the issue. I know when you buy through mioglobal.com their customer service is excellent.
3helpful
I have a mio watch,installed new battery.hear rate monitor does not work,much too high
Have you contacted their customer service team? They are great at resolving issues and really stand behind their product. Their Facebook page MIOWatch also has lots of troubleshooting and FAQs too.
1helpful
I misplaced my instructions on how to use my Mio Sport watch. I do not know how to set it up at all.
Use this link to download instructions for your Mio Sport watch:
http://www.miowatch.com/node/80
Do not forget to rate,please.
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Top Mio Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Mio Watch Expert? Answer questions, earn points and help others
