Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish Network DVR VIP722 freezing up during playback
I'm experiencing a problem with my Dish Network VIP 722 DVR. When playing back a recorded program, it freezes for a while, and then finally "catches up" and continues playing. I've also been needing to reset it more frequently due to just complete locking up.
In the system info details, my Values all seem normal except #7 is -2...is that related to a problem, and will Dish offer me a fix/replacement?
Thanks in advance for your help.
  • 4 more comments
  • lovitts Mar 02, 2009
    After contacting Dish Network for the 3rd time, and going through all of the process again...
    The rep seemed unable to comprehend that my problem was occurring during playback of recorded programs. She kept trying to fix my live tv. Finally, I outright asked them to send me a replacement unit because I believed the hard drive was going bad. She gruffly agreed, and a new unit is on the way.
  • lovitts Mar 04, 2009
    Thanks for the helpful feedback. Does the 222 come with the same software that enables DVR with an external hard drive?
  • Jane Scholl Mar 07, 2009
    my dvr vip722 freezes up, & plugging it in no longer helps
  • kstaver Mar 18, 2009
    I'm on my FOURTH 722 DVR... The first (new) was slow to
    respond to remote from the beginning. After about 4 months,
    it began freezing and shutting down.
    The second did the exact same thing. I could easily reproduce
    the situations that made the unit freeze and crash.
    The third unit (second and third were refurbished units) did the
    freezing and crashing - and added a couple of new "features" -
    beginning recording after the set time - cutting off as much as 30
    minutes of a show - freeze frame while the audio continued - blank
    screen with audio - and, the funniest was "Info" indicated one
    show, with the audio of that show, with the image of a different
    show.
    They finally replaced the unit with a brand new 722k - the latest
    receiver.
    It also began recordings after the timer set time. At first, the
    unit was very quick to respond to commands. As time went on,
    the unit slowed down.
    I woke this morning to more than a dozen 2, 3, 7, 10 minute recordings
    of shows.... The unit was shutting itself down every few minutes.
    It's been doing so for the past 4 hours - that i've been awake. It
    was doing this for quite some time before I woke.
    I'm trying to get everything on the unit moved to my external hard
    drive but only have a few minutes before it shuts down again.
    Everyone at Dish has been making me feel as if this is something
    that I'm doing wrong instead of admitting that the unit is flawed
    and recalling them.
    They insisted that the problem had to do with the outlet the unit
    was plugged into.... or, that it is too hot where the unit is located.
    We have frequent brown outs and power outages so, the unit is
    plugged into a UPS. I unplugged the unit and plugged it directly
    into a "grounded" outlet. Still the same freezIng and crashing.
    Does anyone know what is being used for hard drives in these
    units?
  • dgm1956
    dgm1956 Aug 26, 2012
    Its a software problem with all their DVR equipment
  • jimh749
    jimh749 Feb 19, 2013
    mine is freezing up every top and bottom of the hour,, the screen skips and the sound stops for just a second
  • 374 Answers
You more than likely are 100 percent correct.This is often the cause of the issue you had. The good news is that once the new receiver is in place you normally will not have any other issues as this receiver model is very reliable. One thing to consider is that Dish has some HD receivers available e.g. 222 etc that are non DVR but can act as a DVR unit with an external hard drive connected to the USB expansion port. This option gives you greater control of your recordings and eliminates the monthly DVR fee. There is a one time fee of 39.99 to make the USB port active but within the normal 24 month contract period that customers are often under one will have recovered all of the cost a the hard drive and the port activation fee. Just fodder for thought.
Posted on Mar 03, 2009
  • Kenneth Blackstock Nov 04, 2014
    MY DIRECTV DID THAT.BUT MORE IT GET STUCK ON CH. IT STAYS ON 1 LIKE 3 AN THE VID CHANGES TO DIFF CH. IIT TOOK 8 DVRS TO GET IT RIGHT IT IS THE 8TH ONNE DID RIGHT
PARTIAL SOLUTION
We have had the exact same problem with two Dish VIP 722 DVRs. The first exhibited the exact same issue with freezes and audio going out of syncy, this then progressed to a freeze when the entire HDD crashed and the DVR capabilities would not work (still operated as a receiver). Dish were nice enough to offer 1 day of compensation and magnanimously covered the cost of shipping, they were unsympathetic to asking for 1 month of service to be waived as we'd lost a month of recordings of our favorite TV shows which we'll never be able to catch up on (Lost, Desperate Housewives...)
Dish also made it seem like our unit/our problem which was preposterous.
We're now on our 2nd DVR and just 1 month in it started to exhibit the exact same issues - freezes/audio out of synch.
HEAT COULD BE THE ISSUE
Our DVR unit has been in an enclosed Pottery Barn cabinet with a glass door. As a result a potential cause is heat. If you go to Menu > 6 > 2 you can get to Diagnostics and Counters. Page down to the Hard disk temperature diagnostics. We were getting High 138/Avg 129/Low 122.
We've since taken the unit out of the cabinet and the temperature avg is below 120. We're still getting freezing though.
Dish made no efforts to tell people to keep their units cool or in places where air can circulate.
I think Dish really needs to issue a recall and pay to have better fans put in these units. People should be warned about these 622 and 722 units.
Posted on Mar 11, 2009
I have had 4 VIP 722 units over the past year. Each and every one of them begins to lock up completely about 60 days after recieving them. The picture freezes & no sound. They never reboot themselves, so I have had to do it manually by unplugging them. My recent 722 is their 722k unit. I was told that I should not have any more problems. WRONG! Again, alomost 60 days in, The lock ups continue and still no clear reason as to why this is happing.
I've been given the following excuses by DN:
Poor Grounding
Bad Cabling
Bad Outlet (power)
Corrupt Software, etc
Whats funny is that DN is the one that has done ALL of the installations, servicing etc. None of the recievers have been placed near any heat producing items (TV or other electronics), They've been out in the open, never enclosed.
What I have noticed is that when these lock ups occur, is that when I check the Hard drive temps, they range anywhere from 114* to as much as 140*. However, what all 4 units have in common is the 140* temp. Since I work for IBM in theiir stress test facility in Charlotte, NC, Like many other electronic facility, there is a stress temp bench mark of 160*, at which point, if a unit is going to fail, it will be at the sustained temp of 160*. And since all 4 units share the same exact 140* temp, I'm inclined to believe that the 140* temp is their (DN's) bench mark heat stress test bench mark.
The Units I've had, including this one, mainly have been from 114* to 126*, with an average of 118*. So basing this upon the above, It is very possible that the ventelation could be causing these lock ups, as computers and most electronics, are designed and require to be opperated in no more than 100*, internal temp.
Any Ideas?
Thanks
Posted on Aug 14, 2010
    Problem Solver:
  • 16 Answers
Unplug your receiver box from the electrical outlet for 15 seconds. Then plug the receiver back in, and press the power button on the front panel of your receiver box. Wait for at least 2 minutes for your receiver to power back on. Then it would show you the attention 015 acquiring satellite signal. Wait for the progress to reach 5 out of 5. Then attention 330 would show or the downloading program guide. Press select to momentarily cancel the download and see if you have a picture. If you have a picture, try to use the DVR functions. If they work perfectly fine, press guide on your dish remote followed by 999 then select. It would resume the download of your programming guide.
Posted on Mar 26, 2010
4 Suggested Answers
SOURCE:
  • 374 Answers
SOURCE: Dish network dvr vip722 freezes
I am sorry to hear of your issue and I wish I was able to bear better news but I am afraid that once there is an issue with the internal hard drive there is no way to retrieve the information off of it using common methods such as using on screen prompts or at least that is what technical support has stated.I am sure you already know that Dish charges a one time fee of 39.99 to make the expansion USB port active so that what you are asking is possible. If you have not paid the 39.99 yet I would call customer service to see that if you do so and the receiver is downgraded to a non dvr unit would they transfer that fee. I expect they would not and my suggesting that is that on a non dvr unit I know you can access the information on the hard drive if the receiver is malfunctioning. I know you are probably very frustrated to say the least right now but if you are interested is discovering other possible set up configurations Dish offers a Sling box which is integrated with your internet connection and is very fascinating with the possibilities it provides. Thanks for using Fix Ya and if I can be of further assistance please let me know.
Posted on Mar 08, 2009
  • 56 Answers
SOURCE: Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
Posted on Dec 02, 2009
  • 374 Answers
SOURCE: dish 622 freezes up
You have a hard drive failure and will need the unit replaced. Thanks for using Fix Ya.
Posted on Mar 01, 2010
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: kimberly.escobar@dish.com with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Dec 14, 2013 | DISH Network ViP 922
Is this resiver HD ?
am_witek,
Our 625 receiver is not an HD model. Our current HD models are ViP 211/211k, 222, 612, 622, 722/722k, 922, and our Hopper receiver.
If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Nov 24, 2012 | DISH Network DVR-625 DTV Receiver /...
How do I switch my dish network dual vip 722 receiver to the other tv?
Hi my name is Mike Houston, a Social Media Representative atDISH. To get the full experience of HDTV for your new LED HDTV, you will wantto move the receiver to the living room. I will leave you my e-mail; michael.houston@dish.com, and I willbetter assist you.
Apr 28, 2012 | DISH Network ViP722 DTV Receiver /...
The DVR (Duo DVR VIP 722K) stalls in the playback of the recordings. This results in the receiver having to be reset to watch tv - very irritating. We have learned that it is better not to record two...
Hi 97smash, my name is Mike Houston of DISH Network and I see where thereceiver needs to be reset for it to watch TV. There are some things you cancheck to clear up this issue, please select the buttons of MENU-6-1-1 andselect Check Switch and then Test. After all the test complete please try torecord a new program or show to make sure it plays all the way through, if youhave any questions please e-mail me at michael.houston@dishnetwork.comand I will be able to assist you more with this issue.
Apr 24, 2011 | DISH Network ViP722 DTV Receiver /...
I have just purchased an avex universal urc-r6 remote and i cannot seem to find the way to program it for my vip 722 dvr receiver.
Hi tesmathwi572 my name is Mike Houston of DISH Network andI was going over your post and with our DISH remotes that go with the receiverwill give full functionality to change the channels as well as the DVR andaccess the Menu. Buy getting another remote from a store may not program to thereceiver to change the channels, if I can check your account information suchas account number or phone number so I can see about getting the remote thatgoes with that system. I will leave you my e-mail so you can contact medirectly. michael.houston@dishnetwork.com
Feb 23, 2011 | DISH Network ViP722 DTV Receiver /...
Why wont my vip 722 receiver from dishnetwork stay running
Hi ormsethkellymy name is Mike Houston of DISH Network and I was going over your post andwanted to check something's with your receiver. If you're watching a programand do not touch the remote and you see the receiver go off you can disable theInactivity Standby, you will want to push the buttons of MENU-8-8 and make sureit is disabled and you will be able to watch a program without the receiverturning off.
Feb 12, 2011 | DISH Network DVR-625 DTV Receiver /...
My dvr 722 is slow in playing back or stops from a prior recording. Do you have a solution?
Hi jrodd1 my name is Mike Houston of DISH Network, if the 722 DVR isslow in play back and stops prior to recording there are some things you can doto get this working right. The first thing you want to do is unplug thereceiver for 10 seconds and plug it back in. This will allow for the receiverto require the signal and will stop the slow play back and stops prior torecording a program. I will send a link to help with these steps. http://www.dishnetwork.com/SupportSection/video
Feb 05, 2011 | DISH Network ViP722 DTV Receiver /...
My dvr shows a 1hr program fully recorded, and begins playback fine. After almost 10 min playback ends but when paused, continues to show another 50 min available.
Hello! Daniel Busa with Dish Network here. That actually happened to me about a month ago a hard reset resolved it for me. If that doesn't do it try deleting all of the recordings that don't play back correctly,reset it again and keep an eye on things, it may be a bad box.
Nov 10, 2010 | DISH Network ViP722 DTV Receiver /...
DVR LOST ALL RECORDINGS (EVEN PROTECTED RECORDINGS), ALL HISTORY OF SEARCHES. TALKED WITH DISH & THEY HAVE NEVER HEARD OF SUCH A THING. RECORDED SEVERAL MORE PROGRAMS & IT DELETED THOSE AS...
Hello, Daniel Busa with Dish Network. If this is still persisting you may need a replacement give us a call or you can contact us on twitter and we will get it resolved.
Jun 28, 2010 | DISH Network ViP722 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
16,813 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
