Instead of getting a blue screen with DVD showing, the screen is gray and Regional Code Error comes up and I can't get that error message off the screen. It won't play the dvds.
DVDs can only be played on DVD players with the same region code. You can get a dvd copy without region code so that you could play it on your dvd player, You could tryLeawo DVD Copy to remove the dvd region code
You need to change the region code in the user menu under dvd settings.
David, I have the original remote, I've changed the batteries, I've cleaned the dvd player with a disk. It still says Region Code Error after "Reading". I cannot or did not get a user menu settings to come up on the screen. I can find nothing about region codes in the original Owners Manual.
In that case you need to replace the dvd mechanism assembly
