Uniden DECT 6.0 Cordless Phone ID Logo
Anna Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set up outgoing message?
How do I reset the outgoing message?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Mar 19, 2013
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442366
Points
622693
Since you didn't state the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
I have recorded a personal outgoing message & when I play OGM my personal message plays but when I ring the phone I get the factory set message & once when I ws in my house I could hear both
Try erasing the default message and then record your message. Unfortunately, you may have to do a factory reset if the electronics are "stuck." Bummer.
How do I reset the outgoing message on a Uniden Dect 6.0 cordless phone?
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
How to reset the ongoing answer back to the manufacturer's outgoing message
Once the manufacturers message is deleted it is not available unless it was stored elsewhere.It will be best to check with your dealer to confirm on this or you can always get someone to mime the same tone voice.
My sony ericsson satio can't send messages
In the message settings msg center number may be changed. Please check with your service provider and input the correct msg center number.
I can't find my manual for my phillips 145 telephone answer machine and I need to reset the outgoing message
you need to contact your service provider for your msg centre number before you can send or receive your msg bt make sure you enable all outgoing and incoming msg first in msg settings.
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Text sends as "picture message"?
master clear and reset the phone this might help
menu
settings
initial setup
master clear - 000000
master reset - 000000
3helpful
5answers
Text messaging problem
Delete everything in your inbox and outbox. That solves the problem, I promise. Apparently this is very common with Razrs.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
