SOURCE: LCD TV
i have a samsung 40 inch lcd and any black in the picture has red hue to it any ideas on how to fix?'
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
SOURCE: No Sound on Samsung HDTV? But there is a picture...?
have you tried to umplugging the tv and let it sit for a little while. I would unplug the tv like before you go to bed and plug it back in in the morning and try it
Testimonial: "Well, I unplugged it for several minutes, and that was enough... thank you very much!"
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
