I press every button but it just keeps beeping, I usually don't us the timer for anything I just bake and after a while it show oven on , preheat and the just start flashing F2 and won't stop unless I cut it off.
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
SOURCE: F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
SOURCE: Kenmore Oven going crazy
The bang may have been an element arcing over. Turn off the power and remove the element. If it shows any form of damage, replace it. If you're not sure, use a continuity checker to check it. If you have two elements...do this for both. You will likely find the problem.
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
